web page not working for vi when launched from testsetand
we've setup a web page for a vi in labview (web publishing tool) and its visible in IE until you close labview
this vi is then run from teststand thou the web page isnt being updated?
we need to be able to view the contents of the vi remotely
(2,654 Views)
Would it be possible for you to upload either the programs that demonstrate this (if not too large) or quickly create a program and run instructions in order to replicate this behaviour here? Also which versions of TestStand and LabVIEW are you running?
Once I have this extra information and code I will replicate the issue here and look into it further for you,
All the best,
(2,631 Views)
hi
we're using testand 3.5 and labview 8.0.2
the project only has a vi with an updating gauge on it then used the web publishing tool to deploy it
works fine in the environment but not when the vi is launched from teststand
thanks
(2,629 Views)
I am looking into this issue for you now, in the mean time I'd suggest posting this on the teststand section of the forum to gain more interest from other members.
All the best,
(2,612 Views)
