01-05-2012 10:22 AM
I create my web page with Web Publishing Tool.
I select Monitor option (multiple snapshots that updates continuously).
I ask if it's possible to edit mages.
Particularly need to modify the resolution/dimension/proportion of images.
01-10-2012 08:02 AM
Hello Lesterino,
Do you create an Application in order to see the results using Web Server? You .vi is being executed in RT target or in the host?
In case you create an application, you can edit some options like Window Appearance and Behavior, and some Execution options when you try to create your executable through the Application Builder, before you try to use Web Server.
http://digital.ni.com/public.nsf/allkb/97DB0096CF9321688625759F004C5163?OpenDocument
Have you tried to change these properties before creating your application?
01-12-2012 08:44 AM
01-12-2012 12:07 PM
Yes I understood what you desire.
I suggested you the above Knowledge Base article because by creating the executable you can also publish your front panel but change also the properties that I explained above.
Another idea would be to change the resolution of your vi's front panel programmatically. In this way you will be able to change the resolution of vi that you publish in the web.
Maybe this article would help you too. Its is just an idea.
http://digital.ni.com/public.nsf/allkb/048C31D73E8EC91286256E440063E1BB?OpenDocument
