web publishing tool
I am using the web publishing tool in the upload a control panel to internet. In my VI, there is a sub-VI that creat by IMAQ vision builder. This sub-VI have an script that' Image buffer: retrieve copy' which will return the image that i snapped in new window.
But I found that when i am using the IE to control the main VI, the image cannot be returned. Anything can I solve this problem?
Thank you very much
Ivan
(3,021 Views)
Hello Ivan,
You may want to take a look at this Knowledge Base entitled Can A SubVI Open Its Front Panel When Using Remote Panels?
As this KnowledgeBase explains, your subVI window should open up if you specify the subVI to open when called. You can do this by right-clicking on the subVI icon in your program and selecting "SubVI Node Setup..." and activating the "Show Front Panel When Called" checkbox.
I hope this helps! Please let me know if there is anything further I can help with.
Liz F
(3,020 Views)
