web publishing tool
I am trying to use web publishing tool...I have put on the web server enable.....I am trying to see preview on browser...But everytime error message comes
The requested URL could not be retrieved
Unable to determine IP address from host name
The cache was not able to resolve the hostname presented in the URL.
 Check if the address is correct.
What should I check..
(3,929 Views)
Try to repair network connection.
Try disable firewall.
Try access the web server using the IP number.
(3,916 Views)
disabled firewall with same results.
I can ping my pc with my computer name and it is in local network. I checked with pinging from other pc, its ok.
Is there any labview 2009 version problem??
(3,892 Views)
Can you try a local test? Try acess o the same machine via http://127.0.0.1.
If dont work the problem will be the web server.
(3,882 Views)
its been two years since.....but still I am looking for solution....http://127.0.0.1. gives webpage of "Labview Web Server"...error is same..."domain name does not exist" adding to previous mentioned...
Is there any specific URL that should be generated...which is missing in my case? My network use proxy settings to connect with internet...can this be a problem?
(3,714 Views)
I just want to know something about your system.
1. Operating System
2. IIS Status
3. Browser
4. Configuration Step (Whatever you done to configure web server)
5. Where you are trying to open the page (LAN or Internet)
Share some information with details then only we can help you to get the result.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,706 Views)
Thanks....Himanshu..
1. Operating System : Vista business
2. IIS Status: What I should check?
3.Browser: IE 9
4. Configuration: Enable web server in the option, Allow access.
5. I just try to see preview in browser, but it says Unable to determine IP address from host name ...
However, with same setting when I operate at my home (no proxy setting ) it works....
(3,702 Views)
