web server log files under LabVIEW RT
Is there any log files for the web server under LabVIEW RT running on a PXI?  The log file checkbox is disable in the target options.
Also, is there a way to find out if the web server is running on the target?
I'm asking the question because I can't access anymore a remote panel (and even the root of the web server) on my PXI.  I reinstall everything and I still have the issue.  I'm pretty sure that IT changes some network settings but they say no.  I need to validate that everything is working on my side before before taking further action.
Patrick
(3,175 Views)
Hi Patrick,
I would suggest having the log file checkbox enabled in the target options.  That should show if errors are occurring while it is running. Are you running remote front panels and web services, or just remote front panels?
Can you provide a picture of all the software you have installed on your PXI?  You should be able to find this in MAX under the PXI in Remote Systems.
Scott A
SSP Product Manager
(3,163 Views)
The log file checbox is disabled (gray out) under the target options.
There is currently someone at the customer site to reformat the target.  Will see if it solve the error...
Patrick
(3,151 Views)
That sounds good.  Be sure to let us know if reformatting resolves the issue.
Scott A
SSP Product Manager
(3,140 Views)
Reformatting the PXI and redeploying the application solve the issue.
Patrick
(3,129 Views)
