web service
Dear Sir,
I am using labview 8.2 and unfortunately I cannot upgrade. The problem I have is that I cannot create a "Web Service (RESful)" under any of my projects "Build Specifications" because under that menù this item does not appear. Do I need to install a missing driver or is due to Labview 8.2?
thank you fot your help.
cordially
Giovanni Balbinot
(3,498 Views)
Usually you need LabVIEW 8.2 Full Development System for Web Service VIs.
(3,491 Views)
Thank you for the reply but I have it.
(3,468 Views)
