web
Hello all.
I have created VI and I want to Web Publishing.
And I have created an Image by Flash MX.
But when I added Image to VI  and  Web Publishing,  I don’t see the Image. I only saw the VI without the Image.
What do I do?
Thanks.
Aleksandr.
(3,483 Views)
Aleksandr,
I'm not sure how you are currently trying to incorporate a flash animation into your VI, but the only way to do it that I am aware of is to use ActiveX. This KB [link removed; article no longer available] talks about how to implement this concept.
Kind Regards,
E. Sulzer
(3,460 Views)
Hello E. Sulzer
Thanks for the answer. I will be try.
Please , answer me else:
If I have PDS of LV7.1, may I use the ActiveX with Visual Basic?
Best regards.
Aleksandr.
(3,438 Views)
Aleksandr,
Again, I'm not sure what you mean by "use ActiveX with Visual Basic" as I don't see how the two are related. Separately in LabVIEW, you can use ActiveX by using property/invoke nodes and you can call compiled Visual Basic code in the form of a DLL by using a Call Library Function Node.
Kind Regards,
E. Sulzer
(3,422 Views)
