webservice fails to deploy
Appears as tough we cannot deploy the webservice.  The double slash in the file path is kind of freaking me out.
Then I get this
(3,106 Views)
Hi Tsksesa,
I think you are correct that it is the double slash that is causing the problem. I found this KB that is related to this problem but does not have a solution that will work for you I don’t think http://digital.ni.com/public.nsf/allkb/7BEFCE8EF550EE838625788B0076C075?OpenDocument. Is this file path one that you specify or is it automatic? If you can choose the file path I would recommend moving the file to a different folder and see if you can select it and hopefully the \\ will not be a problem. If you could give me more information about when this error shows up that would be helpful.
Scott B.
AE NI
(3,073 Views)
