weighted mean
I want to calculate weigthed pressure mean ,weigthed mean value, Geomatric mean and standard deviation .
Can anyone help me.I am new to lab view
(6,085 Views)
This isn't actually a LabVIEW question, it is more of a math question.
Once you know the math to calculate these things, then you can implement that math in LabVIEW code using many of the basic math primitives.  For a normal mean and standard deviation, LabVIEW already includes functions to calculate them for you.
(6,083 Views)
thanx for the answer i know it mathematically but i dnt know how to use them in labview thas why i posted the question
(6,077 Views)
For standard deviation, there is ready-to-use function (hint: use quickdrop).
There is no pre-written weighted mean function as weighing is very specific..... but you can have an unweighted mean again ready-to-use.
Norbert
Norbert
Expert: Geometry
(6,064 Views)
Weighted Average is typically just a simple multiplying of two arrays (the array of data and then the array of weights) and then summing the array (Add Array Elements will be useful here).
(6,039 Views)
... if the array of weights is normalized so the elements add up to a sum of 1. Else you also need to divide by the sum of weights. (details)
(6,021 Views)
