weird installer fault
I have created two applications in labVIEW 6.0.2, i install the second application as an addon to the first in a sub-directory. I install the main application first, but when i install or uninstall the second app, the first one runs. I cannot understand how an installer, can run another application unrelated to it. I belive it is something to do with it being in a directory above, but have no idea how to cure it. Can anyone help????
(2,531 Views)
Tom,
I can't offer you too much here. I've never heard of this happening, and it's mighty strange behavior. I would try installing the second application in a different folder just to see if the folder structure is the source of the problem. Let us know if it still exhibits the same behavior or not.
J.R. Allen
(2,531 Views)
