wf end time tdms
Good morning,
I am using a cRIO 9068 to acquire different modules in the LabView Program.
I acquire and save data with the tdms functions. I have been able to add the starting moment of the acquisition with the wf start time. Is there a way to add also the wf end time?
I can't use the daqmx functions because not compatible with the model I'm using.
Thank you.
(742 Views)
Please refrain from creating a new post for the same question.
Duplicated with Include timestamp FIFO high data rate
https://tmesystems.net/
(693 Views)
