what VI called the SubVi
Is there a way to know what VI called the current subvi that is running. For example I have a subvi module that is called by ~4 different VIs. I want the SubVi to know what program called it (or if noone called it and I just ran it) so that it can print this to a file when it saves the data.
Michael
(2,749 Views)
Just have all the callers pass their name as a string to it.  Then have it write the string to file.
Message Edited by JeffOverton on 09-18-2008 03:42 PM
(2,745 Views)
Use the Call Chain function on the Application Control palette.
(2,740 Views)
