what amplifier will recomended for my k-type theromocoupler using usb 6008
I recently do a project about temperature control system using usb 6008, according to the spec, the minimum AI range is +/- 1V and the thermocouple giv the voltages in jz a mV, so what kind of amplifier will be recomamded? is there any amplifier chip set that available ?
(3,432 Views)
Analog Devices AD594/AD595 Monolithic Thermocouple Amplifiers (Type J / Type K)
This would give you a conversion of 10mv per degree C using a single +5v supply you could get to a couple of hundred C
I get 11 bits of resolution available for the +/- 4v range (11 because I can't see a negative supply available so we are only using one side of the differential range).
That's a resolution of 2048 bits over 4v giving 0.001953 v per bit
The devices above give 10 mv per degree C so you would have about 0.2 C resolution and a maximum temperature of around 450 degrees C an minimum temperature of 0 degrees C.
The device draws about 1mW so you should have no problems with power consumption. (Hint Earth / Ground loops might be a problem).
I should add that whilst I have used this device many hundreds of times, I have never applied it to the USB 6008.
http://www.analog.com/en/prod/0%2C2877%2CAD594%2C00.html
Message Edited by Conseils on 05-08-2007 08:51 PM
Message Edited by Conseils on 05-08-2007 08:52 PM
(3,424 Views)
Message Edited by jex on 05-10-2007 02:11 PM
(3,390 Views)
Well a different thread...... but yes I think it should do nicely.
Try and use one thread next time...I think you deleted the response before I had chance to finish this one..... Smiley Wink
Ohh yes and your English is probably better than my "fill in your language here" .... Smiley Wink
My tip is set up the amplifier on a prototype board before putting it onto the 6008.
Take great care over the power supply connections to the device.
CHECK and RE-CHECK the circuit, especially for short circuits, there is a fuse on the USB 6008 / 9 series circuit boards but I wouldn't want to rely on it. (its surface mount and could be fun to replace if it's not a re-settable type).
Good luck
Message Edited by Conseils on 05-10-2007 09:24 PM
(3,385 Views)
