what are the code library function settings should be followed
i have written one win32 dll, in that what are the project settings should i follow to access the dll file from the lab view..
i have done the following changes but still its not working,
1. Added the library.lib to the dll from the installed path of lab view
2. project settings > settings for All configuration
>C\C++ : category :code generation
use run time lib : Multi threaded dll
processor : blend
struct member allignment :1 byte
call convention : _cdecl*
For my driver access i have included the sys file.
is that anything i have to do other than this,  please tel me the config i hav do for the access
(3,075 Views)
2716jag,
How are you trying to access the DLL from LabVIEW?  Have you tried using the Call Library Function Node?  This should allow you to access the functions within the DLL.  I hope this helps!
Brian T
(3,043 Views)
hi ,
Iam using that call library function node. the thing is i created the dll using VC++, so wat are the project settings i have to do in that vc application to access the dll.
(3,034 Views)
Did you follow the steps in this document?
Brian T
(3,021 Views)
