what cast type are used for?
In the example attached to this question is a simple VI application that cast, using type cast of LabVIEW, one value to different other type. My understanding of type cast, in C, C++ and to my best knowledge, was an implicit adaptation of a numerical value in a specific format to an other format. The value should remain the same. Unless the type in which the value is assigned is not enough large or adapted to contain such a number ex:
I8 = 500;
U32 = -1;
But in my example all the assigned indicator are large enough.
I have the same problem in LabVIEW 5.1.1 and 6.1
If someone could only tell me what it is used for?
Nitrof
(2,798 Views)
The type cast function is really helpful for typecasting "unusual" data to a more convienient data format. It can also be used to coerce data, like in your example, but coercion is usually not always a good thing because it can cause bad values.
There are lots of good examples of typecasting.
For example, I use the typecast function to change refnums to unsigned 32 integers (U32), just so I can pass the refnums between VI's easier.
Another VERY common typecast is if you want to display the ASCII value of a character. Run the string character "A" into a typecast, and set the output type as a Unsigned 8 bit number (U8), and you will see 0x41. Take a look at my example VI's to see what I mean.
David
(2,798 Views)
All a type cast does is tell LV to interpret a specific value in a different way. For example, casting a -5 as a U16 (which isn't valid anyway: no negative values) LV interpretes the bit pattern contained in the input value--or at least the first 16 bits of it--as a U16 and comes up with the correct answer: 65536
In the same way, LV tries to interpret the I32 bit pattern for -5 (1111111111111111111111111111011)as a value of each of the types you specified.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,798 Views)
