what do i need to measure muscle activity
Can some body explain what i need to  measure muscle activity?
i have a 6210
so  i have to buy emg sensors  but   ,do i need amplifier for this signal ?   can i use amplifier that i use for strain gauge's?
what elso on hardware side do i need?
Message 1 of 8
(3,937 Views)
You need a biopotential amplifier.  Please refer to this document on our Biomedical User Group website.
Message 2 of 8
(3,935 Views)
is this also true for a 6216?
Message 3 of 8
(3,933 Views)
the 6216 because it has bank isolation    not enough?
Message 4 of 8
(3,894 Views)
The amplifier is not needed just for safety - it is also needed to provide the proper signal conditioning before the DAQ device.  You need an AC-coupled, balanced differential input with a high CMRR to block the large DC offsets and reject the high common mode noise (from 50/60Hz line frequency) that are inherent in these kinds of recordings.  NI DAQ devices do not have these kinds of inputs/features.  However, they are great for digitizing the analog outputs from a good biopotential amplifier.
Steve
Message 5 of 8
(3,867 Views)
Hi steve
The problem is there is no ac
Since there is only a laptop
We also do not have any other attachement to a machine or other wise
its for measurement  human emg on a bike
So evrything low voltage
So no noise or strange other things  ,thats why i ask my selve why can i not use the aplifier of strain gauge
Message 6 of 8
(3,864 Views)
You can buy low-cost bioamplifiers that have battery power (these are also safer to use) such as this: http://www.grasstechnologies.com/products/amplifiers/p55.html
The AC line noise (50/60Hz) is not just from AC powered instruments - it is also radiated EMI that comes from lighting, wall wiring, etc. - it is very hard to avoid.  A good bioamplifier will reject this noise since it is common-mode (appears in both electrodes more or less equally) and only the difference signal is amplified and passed to the DAQ device for digitizing.
Message 7 of 8
(3,854 Views)
Ok thanks steve,   i understand now the worry  this also means if your in the field (outside you hardly would expect any noise )
Planned a hospital test on my selve.
I will look what the differnace gone be .
I emailed them (grasstechnologies),  to order it now          hope they want to sell it !
Anyway thanks   meaby talk to you within 2 weeks in (austin)
Message Edited by cees10 on 12-14-2009 02:32 PM
Message 8 of 8
(3,827 Views)
