what does "variable name not defined in meta data error code:-1" mean?
I am new to Labview.  Trying to figure out some problems with a system that uses  a crio 9012 with FPGA.  Where is the best place to start to learn?
(7,034 Views)
Hi Denny,
Can you give us some more information about this error? Where and when does it happen in your code? It is in the host VI or the FPGA VI?
As far as resources for learning, obviously these forums are great. The LabVIEW help has an insane amount of information regarding good coding practices and other general information. The shipping examples are also very helpful, you can find then by going to Help->Example Finder. NI.com also has a lot of useful articles and additional examples on the Developer Zone.
Nick R
NI
(6,997 Views)
Well I'm so new to this that I don't know how much useful info I can give you due to my limited exposure to the hardware and software.  Our machine is run by Labview software on the 9012crio with fpga backplane and about 6 different modules of different type.  We use an advantech screen that I believe is Windows ce based?  The error happens before the network connects to each other and is displayed on the screen.  I'm trying to learn more but it is very slow going.  I have been in the examples, looking at fpga stuff, crio stuff, and trying to make sense of why certain things are and why they exist.  Really appreciate your time and patience.
(6,993 Views)
DennyM,
Take a look at the following Links:
That should give you a good start.
Bassett
Message Edited by Bassett Hound on 09-27-2007 12:45 PM
(6,988 Views)
I appreciate your help.  I believe those links will be very helpful.  There is alot of material in there.
Thanks again
Denny M
(6,941 Views)
Some other useful RT documents are the following:
Communication
Hope that helps,
Bassett
Message Edited by Bassett Hound on 09-28-2007 09:42 AM
(6,858 Views)
