what does this error message mean?
I just made a formula node with "y=exp(x)-x^2;" in it. but it says
Block Diagram Errors
Formula Node: integer type required
Error on line 1 is marked by a '#' character: "y=exp(x)-x^2;#"
what's this mean?
thanks
redoo
(2,924 Views)
Are you using LV 6.0 or higher? If you are then read this excerpt taken directly from LabVIEW help: "Note   The ^ operator, which in pre-6.0 versions of LabVIEW Formula Node stood for exponentiation, now represents the bitwise exclusive or (XOR) operation. The new operator for exponentiation is **, for example, x**y." Change your ^ to ** and you should be all set.
Hope this helps,
Brian
(2,924 Views)
