what is 1900 in NI myRIO-1900
What is "1900" in myrio-1900?
(1,991 Views)
The model number. There is also the 1950, which is for embedded applications.
Are you searching for any deep meaning behind numbers? 😄
(1,988 Views)
Probably v19.0.0 ? (just a wild guess)
In any case, the number may not be significant for a typical user.
Santhosh
Soliton Technologies
(1,984 Views)
The myRIO comes in two model numbers (and has since its release almost a decade ago).  The model 1950 lacks WiFi and the MSP Connector.  It has nothing to do with 19.0.0.  Most users will probably want to acquire a myRIO-1900, unless (as Altenbach notes) you are using it as part of an "embedded system" (but I've seen a number of 1900's plunked onto a motherboard using the two MXP connectors, with a ribbon cable going to the MSP connector on the other edge).
Bob Schor
(1,937 Views)
