what is a tight loop?
What is a tight loop?
(4,702 Views)
 - A term used to describe a code construct that results in repeated execution of the same code with the same results and not releasing the processor for use by other processes. Tight loops exibit themselves as a CPU bound application. Tight loops can be avoided in LV by using a "zero ms wait" (literally a "0" wired to a ms wait timer) in the loop thereby allowing other tasks to be processed. Search this site for the term "cooperative multitasking".
Ben
(4,700 Views)
Also known as a Greedy Loop
Of course, sometimes you actually want something like this, but that's more the exception rather than the rule.
(4,654 Views)
Can you please explain, what happens when you place a "zero ms wait" in a tight loop.
Isn't wiring a zero equilant to not placing the wait function?
Dsk001
(4,597 Views)
No, it's not the same. Wiring a zero allows the operating system to give time to other processes running and return to your program as soon as possible. Wiring a 1 means your program is telling the operating system "go ahead and do other stuff, but when you come back, make sure it's been at least 1 msec before you get back to me. "
(4,592 Views)
That is helpful.
Dsk001
(4,561 Views)
