what is happening - crashing
I wrote a vi using a cin, to try my hand at it, and the strangest thing happens.
As soon as hit the white arrow to make the vi work, and it then closes completely.
Usually if something closes, the labview main screen with new, open, etc
comes up, but it completely closes. I can see that the string that I entered
gets passedback through the cin and appears on the vi, because it kindof
flshes before it closes.
Does anyone have a suggestion what may be happening? all seems to work well,
except it closes as it does. thansk for your help.
JMH
(2,510 Views)
JMH wrote:
> Hi,
> JMH
Check your CIN for memory management routines. You should use LabVIEW
memory manager function calls insude CIN as described in CIN reference
manual. As well, using wrong referenc
es and pointers inside CIN may
cause LV crash. It's normal and warned in that manual made by NI.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(2,510 Views)
