what is running leq
Hello, 🙂
I'm a newbie of LabVIEW.
I'm wondering about a term that is "running Leq".
what is the meaning of running?
is it different from moving average?
thank you for reading!
Sincerely,
Albert
(4,232 Views)
Accepted by topic author AlbertTaewoong
Hi dotolee,
                   Leq is a symbol that represents “Equivalent Continuous Noise Level”. Usually the signal that you are measuring is varying in amplitude. You can calculate the sound pressure (noise) level of an imaginary continuous signal, within a given time interval, that would produce the same energy as the fluctuating sound level that you are measuring.'Running leq' means the running equivalent continuous sound level.
Thanks as kudos only:)
(4,227 Views)
Hi dotolee,
                See SVL Running Leq Sound Level VI
(4,220 Views)
