what is the difference between refnum and path ?
hi !
there is a refnum output from the read/write to file .
there is also a path data type.
can someone clarify a little bit ?
(5,160 Views)
@hookso wrote:
hi !
First, are you referring to a VI that has both a refnum out and a filename out? Or, just stating that there are paths and refnums existing in our world at the same time?
A refnum is a reference to an open file, which you obtain using Open/Create/Replace File.vi or any of the many functions that allow a file to be opened and written to/read from. You can use this refnum to perform operations on the file further along down the line. The refnum is later closed (or at least it should be) with the Close File function.
Note that VI's like Write To Spreadsheet File take a path in and have a path out, but if you look under the hood, it opens a refnum, uses it, and closes it.
A filepath is very similar to a string, in that it only conatins text, even though it is "specialized" text. In fact, paths can be converted to and from strings.
Richard
(5,155 Views)
Accepted by topic author hookso
And as the help explains, you can wire a refnum to the path input. Please note the different behavior when you wire a path or a reference.
(5,150 Views)
Oh that's just great.
Richard
(5,106 Views)
