what is the process to monitoring and control some reservoir and pupm?
Hi Behzad,
why don't you tell the full story in the first place?
You already know what you want tu use,  from inputs to algorithms.
When you mention "Excel file" you should use the RGT toolkit. (You don't speak about plain CSV files, don't you?)
When you mention mathscript you need the toolkit that enables mathscript usage in LabVIEW.
When you mention "hardware connections" you should read the manual of the hardware you plan to use…
Message 11 of 23
(1,753 Views)
Hi gerdw
thank u.
I have mathscript toolkit. I have RGT part, I attached that's picture, is not complet to use fot Input/Output Excel files?
Message 12 of 23
(1,747 Views)
Hi behzad,
use RGT toolkit for (real, proprietary) Excel files. There are a lot of discussions about "Excel files", read them!
Now all you need to do is applying your algorithm to your input data sets… 🙂
Message 13 of 23
(1,743 Views)
tnx, I will try to find discussions, but please say me, I need new toolkit of RGT? or my RGT is complet?
Message 14 of 23
(1,739 Views)
Hi Behzad,
you already have RGT installed. Yes, it is complete (or should be as far as I can judge from your image).
Message 15 of 23
(1,734 Views)
Hi GerdW
I couldnt import and use excel files to my labview program. can u help me more? I read a lot of topic and posts, but I couldnt yet.
Best Regards
Message 16 of 23
(1,688 Views)
Your image of the palette only shows the standard report functions that come with LabVIEW and none of the Excel or Word palettes. Are you sure you bought and installed the separate toolkit?
If so, attach your code and explain your exact difficulty.
Message 17 of 23
(1,673 Views)
Hi
Message 18 of 23
(1,660 Views)
Yes, that is the correct palette. No, you can't read native Excel files without using ActiveX. The toolkit installs some examples.
As mentioned before, you can export the Excel file as a csv file which is a plain text file readable with the Read From Spreadsheet function.
Message 19 of 23
(1,654 Views)
tnx a lot
concep of active x? and how can I use that?
Best Regards
Message 20 of 23
(1,642 Views)
