what is this icon called and located?
(1,527 Views)
Accepted by topic author gptshubham595
Call Library Function Node.
Connectivity Palette >> Libraries and Executables.
The orange color indicates it is set to run in the UI thread.
(1,522 Views)
Do you see the "picture of books and book-ends" on the center of the orange part?  Does that suggest a "Library" to you?  This is the "Call Library Function" node, found on the Connectivity VIs and Functions palette's "Libraries & Executables" sub-palette.
Bob Schor
(1,516 Views)
  • If you are looking at it on the diagram, do a "right-click...help". For further information, double-click it and look at the configuration.
  • If you are looking at it on a picture, knowing the name of the function will not really help you, because it will not tell you what's inside (name of the DLL, calling convention, configuration, function names, etc.)
(1,501 Views)
