what is this icon name? in numeric
i need to make a graph with 2 variable
(858 Views)
BuildArray…
(841 Views)
And if you need "to make a graph", then you can do it, but makes not much sense for two scalars.
Build Array located in Array palette:
(823 Views)
Yes, it is "built array" (In the array palette, not in the numeric palette!) but since you only have two points, a graph would be quite boring. Maybe you want to use a chart instead that would show the two values as a function of time, updated with each loop iteration. (Make sure you know the difference between a graph and a chart!)
Can you point us to a link where you found that picture? We can typically give much more specific answers with some context.
(785 Views)
