what kind of camera can I use??????
I need to measure crack length in fatigue test of an Aluminium sample automatically. For example, the camera can take shots (Images) every 4000 cycles (fatigue load cycles), maybe more cycles.
For my test, I need to measure both sides crack length (right side and left side of specimen centre line), shown in Fig1.  So I need to take shots both crack tips at the same time, which means camera must have a large field view and the resolution should measure 0.01mm, to see both crack tips clearly. At the end, I must be able to acquire images from Labview. I can save all the images into my fold from Labview, then I can measure crack lengths in left and right side from every image.  Fig1. sample size and crack tip
Would you please give me any suggestions on the characteristic/specifications of this kind of camera?
 What kind of camera can I use? How much this kind of camera? Where can I order this kind of camera?
(2,511 Views)
(2,507 Views)
Hi Cran.
You might want to put this topic into the Hardware Forum instead.
It seems that this isn't much of a LabView question......
Regards BCL
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(2,490 Views)
