what kind of joystick are supported by labview 7.0?
Dear all,
I'm going to use a USB 3D joystick (very normal one, which people used to ues it to play game) to control a 3D XYZ stage movement.
now I'm caring what kind of 3D joystickk works in Labview 7.0? need any special joystick?
thank you very mcuh
Wei
(2,913 Views)
weichengatech,
I've looked into the specifics of the using a joystick and found a very good article that I think will point you in the right direction. Check out the knowledge base titled Can I Monitor a Joystick or Gamepad in LabVIEW 7.x? Basically, the vi's can be used with the USB HID (Human Interface Device) class of hardware. Please post if you have questions.
Best Regards,
Chris C
Applications Engineering
(2,899 Views)
thanks ,chris,
I'll go to have a try 🙂
best
wei
(2,880 Views)
