what's different between event create and register
I don't understand the detail position of the event create and register, I want to know the theory behine the functions.Someone give info?  Thanks!
(4,599 Views)
If you are asking position and how to use check this link: https://zone.ni.com/reference/en-XX/help/371361K-01/lvhowto/creating_user_events/
-Event structure has tw types of registering events static and dynamic.
-In static event registration is performed automatcially when a VI with event structure is run for all the user interface events.
-Whereas Dynamic event registration is custom user based and without user interaction you can create an event based on predefined condition.
-Create user event is used to define the event type and the cluster input name is what becomes event name.
uday
(4,582 Views)
Thanks udka!
Sorry for my out of focus question!
I found that I can just use event register function to to define the event,so I don't know the necessary of the create function? so as to destroy function.
Alex
(4,574 Views)
Accepted by topic author Alexleung
You can define the listening part to an event in register for events.
-Create and destroy functions are required for user events.
-if you are still talking about front panel events registration, yes you can do dynamically register for events and you don't need create and destroy user event: https://zone.ni.com/reference/en-XX/help/371361K-01/lvhowto/dynamic_register_event/
-If you can post vi/snippet it might explain a bit better of what you are asking.
uday
(4,567 Views)
I got it,Thanks! udka!
Best regards
Alex
(4,557 Views)
