what's the best way to prevent 2 loops accessing to one variable at the same time?
Hello everyone, Happy new year to all you first!
I have a question about preventing two loops accessing a batch of shared variables at the same time in labview.
Right now I am using a 3 frames case in each of the loop. In the first frame, a local boolean variable is set to true representing start of access. In the 2nd frame, the variables are accessed, In the 3rd frame, the local variable is set to false representing end of access. So by check the local boolean variable in the other loop, it will tell the other loop if or not to access the variables.
My other thought is to use a queue to do same job.
My question is, comparing with a single bit-level operation cmd in a traditional programming, these 2 labview approaches seems lower efficiency and it's my concern as my loops executes very fast.
So I am looking for better idea to do the job. Any comment or idea is welcome!
Feilong
Message 1 of 9
(3,213 Views)
i have a bit of troubles understanding what you are doing:
are you using the same set of locals in all 3 loops? if yes, i would propose to rethink the way you program all together.
it would help if we could see the code tough.
in general, the utilisation of locals is very prone to race conditions, and is the wrong approach when sharing information between different instances.
as a fast workaround you can use Actions engines (AE). they have also limitation when sharing data, but you can use very easy protection mechanism in the AE itself.
... And here's where I keep assorted lengths of wires...
Message 2 of 9
(3,205 Views)
Another option is the use of semaphores.
Depending of your code style....
Message 3 of 9
(3,200 Views)
Another way is to use functional globals.
Functional globals are SubVIs with a while loop running once and a shiftregister to store the value. Another parameter is the command what to do like "Set", "Read", "Increment" ...
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 4 of 9
(3,170 Views)
or in Bens's language an Action Engine, see above Smiley Wink
Message 5 of 9
(3,166 Views)
Hi Gabi1,
I was out of  the forum for nearly a year recovering from a burnout syndrome so I didn't keept up with the things going on.
But anyway thank you for pointing this out.
Waldemar
Message 6 of 9
(3,163 Views)
wireworking related? you are back, thats what important :)
Message 7 of 9
(3,139 Views)
Sorry to hear about the burnout Waldemar. I hope it was not railroad related. BTW: we have have made progress and have started to assemble the steel mill (or in Pittsburhese "still-mill").
Ben
Message 8 of 9
(3,130 Views)
Dear Gabi1 and Ben,
it was the general amount of work, making the CLAD and CLD, having a 10 hour workday and the personal interests. I stopped the LV8.5 beta, the forum here and the forum of the railroad. The railroading brought me up again even with wireworking (scroll down for my post) for it. I started scheduling my day and week and if it is not done within the scheduled slice it will get another slice sometime later. Starting next week Tuesday and Thursday will be my regulary time here in the forum.
Maybe someone has to split the thread and put the last posts into the Breakpoint under something like "The recovery of Waldemar". Smiley Happy
Waldemar
Message 9 of 9
(3,119 Views)
