what symbol is it ?
What is this symbol, and where do I find it on the pallette?
Message 1 of 10
(4,355 Views)
Looks like a SubVI to me, not a LabVIEW-supplied VI.
If you enable paths in the context window you can see the exact name and location of the SubVI.
Message 2 of 10
(4,348 Views)
actually, I get this in the e-book, and I can't recognize this symbol 😞
Message 3 of 10
(4,343 Views)
What e-book are you talking about?
Message 4 of 10
(4,339 Views)
the title is "Developing Neural Network Applications Using Labview" . Can you recognize the symbol ?
Message 5 of 10
(4,334 Views)
I see, a published thesis. The author undoubtedly wrote a SubVI; you would have to scour the thesis or request a description directly.
Message 6 of 10
(4,330 Views)
Not from the fuzzy image on my small screen.
Message 7 of 10
(4,326 Views)
Actually the book is an old one because the subVI you showed is the old mean function that shipped with LabVIEW a long time ago. It calculated the mean, sigma and sigma squared for the input data array. It looks like the sigma squared output is wired.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 10
(4,307 Views)
Just by the picture:
It takes an array and calculates the mean, variance and standard dev.   (and the w is for weightning the input array)
SInce w isn't wired you can use the Std. Dev. vi found in math/stats+prob.
Funny,  (or not) I can't find a mean or stddev vi that has a weightning option....  well, mathscript......
Greetings from Germany
Henrik
LV since v3.1
Message 9 of 10
(4,289 Views)
Mathematics -> Prob & Stat -> Std Deviation & Variance.VI
Weighting input available.
Edit: I should clarify....this is not the same VI as posted by the OP but I would assume that it accomplishes the same task.
aputman
Message 10 of 10
(4,243 Views)
