what the data type of this variant? (in the following)
What's the datatype of the following variant (use probe and indicator):
value -> 1356.00
I want to tranfer it to numerical data. When I tranfer it using "variant to data" function (the datatype used is string or numerical), An error occured:
 ERROR 91 occured at Variant to Data. The data type is not compatible with the data type wired to the type input."
Thank you very much!
(2,944 Views)
You can investigate any Variant by using the 'Variant Probe' for download from LAVA.
It will tell you what the actual contents of the Variant were.
Ton
My LabVIEW Ideas
(2,928 Views)
You can also right click on a Variant control and show the datatype it contains by selecting "Show Type" from the menu.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,914 Views)
