what tools should i add ??
Hi all.
What tools should i change/add so that when i type { eg. 123451R in the ( student admission number text box) } it will only appear other information,such as his name and grade???
Or do i need to make another subVI ??
Sorry for asking so many questions these  2 days :l
Thank in advance 😄
Message 1 of 25
(3,649 Views)
I can't open your VI as Iam using LV2009.
Anyway,from reading your post I have a suggestion use a string array(control or indicator as per your requirement).Then it is possible to enter 123451R.
Thanks as kudos only:)
Message 2 of 25
(3,643 Views)
I don't really understand your question. What exactly are you trying to do? Are you trying to query the DB for the information based on this student ID?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 25
(3,635 Views)
i am using LV2011.
okay i wil try out ur method.
Thanks.
Message 4 of 25
(3,629 Views)
Yup i am using DB.
Message 5 of 25
(3,625 Views)
Btw the way is it  use a string array(control or indicator) at the DB tools select data.vi ???
On the point/pin called "condition" ??
Message 6 of 25
(3,611 Views)
Can you attach a screen shot of your Block diagram?
Message 7 of 25
(3,607 Views)
Message 8 of 25
(3,600 Views)
By doing so,what you are trying to achieve?
Message 9 of 25
(3,594 Views)
when i type something  , eg 123451R, at the "student admission number" ( the textbox) .
I wan to get this student details, such as his name and his grade on the table.
Message 10 of 25
(3,591 Views)
