what versions of labview support database connectivity
I want labview to link the readings I get from my instrument to an oracle database.My Questions are:
1.What versions of labview support database connectivity.
2.Does labview support connectivity to an Oracle Database.
Thanking You in Advance For your Replies!!
GI_J
(2,625 Views)
I have seen Labview support for Access data base. It was easily done using SQL toolkit previously. But i think NI calls it as database connectivity toolkit. So support for data base is there but for oracle database ??
(2,618 Views)
The LabVIEW Database Connectivity Toolkit requires LabVIEW 5.1 or later and does connect to Oracle. You can see more information about the toolkit on our website (linked above). The Data Sheet has some information you may be interested in. I've also attached the Compatibility Readme file below. Thanks for your interest in our products!
Robert Mortensen
Software Engineer
(2,605 Views)
