whats the best way to convert a string into datetime?
hello,
(3,024 Views)
Parse it and rebuild using the time cluster. Here's a VI that's part way there. You can modify it to suit your needs.
___________________
Try to take over the world!
(3,022 Views)
to use the upper example, you have to use a string in the field "time format string" like this: "%S%m%H%d%m%y"
(3,004 Views)
Also, keep in mind that it's nowhere near finished.
I only posted it to demonstrate the concept.
Here's another version with a few bugs removed.
___________________
(2,998 Views)
