when I send date as dd/mm/yyyy to excel spreadsheet with Activex date string changes to mm/dd/yyyy.
when I send date as dd/mm/yyyy to excel spreadsheet with Activex, date string changes to mm/dd/yyyy. I am from Australia  date format on my computer is dd/mm/yyyy.
I have selected date cell format as dd/mm/yyyy. Any ideas. Thank you.
(3,078 Views)
i am from malaysia..can u try to edit your 'regional and language options' in control panel. you can set your long and short date
(3,073 Views)
I found a similar problem. All my settings in Windows were for UK formatting, but on occasions [not always!] the date as shown in Excel was reversed, so I would send, for example 05/11/2009 and the "system" would mangle this to be in May. I found a way round was to send the date as 05/Nov/2009, and Excel would then display 05/11/2009. I did suspect that if the date was valid either way round, as in my example it would be reversed, but if the day was above 12 (as in 20/11/2009) it was OK, but having got a solution, I didn't investingate further.
If you're using "get date/time string" I think that the UK long date format of "05 November 2009" will also work.
I'm presuming the Australian date format is the same as the UK.
Rod.
(3,058 Views)
Similar problem to Rod's one - with Italian date format which is dd/mm/yyyy - when writing dates to Access using the Database module.
When day is > 12, I must prepare the date as yyyy-mm-dd (format for Database module vi's); when day is <=12, the date must be prepared as yyyy-dd-mm.
This problem really astonished me. Must be something about ActiveX and Microsoft stuff.
satinder,  does the behaviour change with day number too?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,049 Views)
