when I try to put a graph from the control palette to the front panel, Labview 6.0 gives the error message "image.cpp line 4144" and closes
Do you have multiple versions of LabVIEW on the same machine? If so, make sure they are installed in different directories. If you installed LabVIEW 6.0 to the same directory without uninstalling a previous version of the software, you could run into issues like this.
If you do not have a previous version of LabVIEW on your machine, this sounds like a corrupt installation. I would recommend uninstalling and re-installing LabVIEW 6.0.
(2,663 Views)
LabVIEW 6.0 has some bugs that are corrected in 6.0.2 update. If reinstalling LabVIEW does not solve the problem, i'd suggest updating it. You can find the update fix in NI website.
Hope this helps
(2,663 Views)
