when I use highlight above some vis appears a green arrow...
...and above some appear three green dots? My application stops at the next sequence structure after the three dots vi, what do they mean, I cannot find anything in the help?
(3,275 Views)
Hi Robert
The green arrow indicates a sub-vi which is executing. The green dots indicate a sub-vi which is pending to execute.
If you keep watching it, you'll see the dots change to the green arrow.
Just have a look at the attached vis. Execute main.vi in highlighting mode and you can see it. In sub.vi I just call the wait-function to make the execution glyphes visible.
Hope this answers your question.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,255 Views)
