The problem occurs (at the very end of compilation)only when compiling one particular bit of code, though reloading a version of that code which had previously compiled, still produced the same error.
I would try uninstalling the Application Builder and then reinstalling it. I would also try doing a repair of the LabVIEW 6 installation by going to Add/Remove Programs for LabVIEW 6 and selecting the reinstall option.
I say this because it sounds like either the Application builder files have become corrupted or the VI Get Section Names.vi from the Functions»File I/O»Configuration File VIs have become corrupted somehow.
Randy Hoskin Applications Engineer National Instruments http://www.ni.com/ask
Yes, i believe you are right. I actually was able to get it to compile by opening up the vi in the Program files/Labview directory and resaving it. Thanks.
