when i run my executable it gives error 7
and this is the error messege:
Error 7 occurred at Invoke Node in PRC_Deploy.vi->Deploy Library.vi->Deploy SV2.vi->WSfrontpanel.vi
and can any one tell me how to deploy the shared variable libraries on my executable file
m.shair
Mahmoud Alshair
Intelligent Systems Integrator ( ISI )
System Developer
(3,636 Views)
Accepted by topic author M.Shair
Hi Mahmoud,
What are you doing at the Invoke Node? Are you calling a vi? If you are check this KnowledgeBase.
For deploying shared variables from your executable, check this KnowledgeBase.
Hillary E
(3,612 Views)
Hi Hillary
Thanx for your concern but I 've already solved my problem and it's working now.
Mahmoud Alshair
System Developer
(3,600 Views)
Hi Hillary
Mahmoud Alshair
System Developer
(3,599 Views)
