when is Key down event case triggered
Hi all,
In event structure there is an event <this VI> key Down?
When will this event be triggered... i.e will this event be triggered only in case of a keyboard entry... ?
Or in case i use a barcode reader, if data gets populated in a control on the Front panel through the barcode reader will this trigger this event...?
(2,898 Views)
The Key Down event will only be fired when a key is pressed on the keyboard.  If you want to fire an event off of a Front panel control, you can either use a User Event or a property node called Value (Signaling).  This property node will cause a Value Change event to trigger when the value of the Front panel control changes.
Cheers
(2,888 Views)
