when opening a lecroy dso driver i get the message "lcwpxxx_32.dll is not a 32bit dll"
I have downloaded an IVI driver for the lecroy DSO Wavepro 960 but when I try to open it in LabVIEW 5.1 I get the above message. What is the problem? And how do I sort it?
(2,603 Views)
This error will usually occur when you are using an obsolete version of the IVI Engine. You can go to http://www.ni.com/downloads and download the latest version of the IVI Engine (version 1.83). This should fix the problem.
Good luck with your application.
Sincerely,
Darren N.
(2,603 Views)
Thanks, it worked ok.
(2,603 Views)
