where can I find TI DWG AcroPDF
Friends,
i got the attached example in discussion forum for open a pdf file .there is a control named TI DWG AcroPDF.where i can find it?
kavi
(2,978 Views)
Accepted by topic author karpaga
First you must have Adobe Acrobat reader installed. That software is free so it should not be a problem. Then in front panel right click on the control and select Insert ActiveX object. Select the Adobe Acrobat Browser object. Then it should work
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,970 Views)
