where can i find description of"DSSetHandleSize" when using CIN
I Studied a example of LV named "Hostname". It call .dll file to realize it. In the source code of the .dll, i found that it use "DSSetHandlesize". I donnot know where can i find the descriprion of it? Thanks a lot!!
(2,525 Views)
gpibssx;
The information you are looking for is in the document Using External Code in LabVIEW, which you can download from that link, or you may already have it in your computer. Look for the document lvexcode.pdf in the manual directory where LabVIEW is installed.
Regards;
Enrique
www.vartortech.com
(2,525 Views)
