where do i wire a butterworht filter into the ai.vi to filter out line frequency noise on low level dc aquisitions?
I am going to assume that you don't have any hardware filtering on your analog input (which would be ideal).
First, you would want to do it on a timed acquisition (buffered). You would apply the butterworth filter VI after reading the data from the buffer through AI Read VI or higher level VIs (such as AI waveform VI). The output from such VIs would serve as data input into the Butterworth Filter VI. You set your frequency information (cutoffs, sampling freq, etc). The filtered data will come out.
Mark
(2,631 Views)
Suppose I want to filter out line noise 50Hz then what is the sampling frequency, and cutt off freq I should input in the Butterworth filter.vi.Which filter is ideal to filter out line noise from a low voltage dc signal.
Thanking you
Himanshu Mishra
(2,631 Views)
