where is my block diagram
my block diagram doesnt exist any more.
i've remotet the pc with labview by pc-anywhere (norton utility).
surprisedly the block diagram is deleted.but the front panel is identic like before.
i restartet my pc but the block diagram isnt there.
is it possible to bring it back.
the vi isnt executable!
if i call the block diagram the block diagramm is empty.
(2,992 Views)
I don't what kind of relationship installing pcAnywhere might have with your problem unless a remote user got in and messed with your code. I'm assuming that you're seeing this problem when you're working locally.
If "Show Block Diagram" is not selectable from the Window menu, then the diagram was deleted by doing a Save with Options and selecting the option "Remove Diagrams". If that's the case, the block diagram is gone forever. If the menu selection is there, is it possible that the block diagram screen is just scrolled to a position that you can't see your code? Can you right click on a front panel control and select "Find Terminal"?
(2,992 Views)
i've tried your suggestions, but they change nothing.
i also tried to get my block diagramm with double click on the objects of the front panel. sometimes one or two wires of the block diagramm were shown and the processor works permanent. after a few minutes i restarted labview.
(2,992 Views)
Hello WeberM,
perhaps you should post your VI here?
(2,992 Views)
