which filter to use?
HI - I have a continous wave laser system which directs its laser output into a photomultiplier tube (used to measure the number of photons in the laser light and provide a voltage signal).
This voltage signal is wired into DAQ  system and a simple program has been created to acquire the voltage signals from the photomultiplier tube. However we have now added a light chopper ahead of the laser beam before entering the PM tube to provide a pulsed signal. The chopper is currently set to 500hz chopping frequency and hence we now get a sinuosidal wave  in our DAQ program.
is there any way to eliminate the sinusodal wavelength from the program through some sort of a filter which would retain the change in laser intensity as if the chopper wheel was not there? We need to keep the chopper wheel in place so i cannot just remove it.
many thanks for your help.
Notay
(2,528 Views)
It might be better to capture the peak values (or average of several samples near the peak if the signal is noisy) rather than trying to use a filter.
Is your chopper a typical "bow tie" mirror or a crossed polarizer which changes amplitude continuously?  The reason I ask is that the typical chopper would produce a square wave signal, not a sinusoidal one.  With square waves it is much easier to track the amplitude variations of the laser.
Lynn
(2,472 Views)
