which is best for image processing labview or matlab.
hi ,can any one  tell me which is best for image processing labview or matlab. if matlab best then why? or if labview is best then why?
(4,064 Views)
Well, first you will have to define what you mean by "processing". It also depends what you are familiar with. If you're an expert in one and have only written "hello world" in the other, you'll probably write better code using the one you are an expert in.
(4,043 Views)
Which environment do you know better? That is generally more important than a specific type of function which might or might not be available in one of the packages.
As you have found out you can do it in both. So if you know LabVIEW well but have little experience in Matlab you will definitely want to go with LabVIEW and vice versa.
Rolf Kalbermatter  My Blog
(4,039 Views)
Thanks for your kind reply. processing mean i want to do object tracking i know both labview and matlab but will you share your knowledge that which is best for my application.
(4,012 Views)
I know Labview better as compare matlab.i have also basic concept about matlab.
(4,011 Views)
Then, you should use LabVIEW, because that will help you to more focus on Image processing than Syntactical errors and very Lower level design.
(4,001 Views)
