which is better for usb camera between VISA and imaqdx in labview 2010?
i have done a program for usb camera to acquire images with imaqdx.
now i want to know which is better between VISA and  imaqdx in labview 2010?
i didn't study visa before
thans for help.
(2,579 Views)
VISA is primarily used to communicate with instruments via GPIB/TCP-IP/Serial/USB. In order to use easily VISA with an instrument over USB the instrument must adhere to the USBTMC spec. A camera is not likely to have this. Otherwise you have to use USB RAW, and that requires detailed knowledge of the data that is transmitted by the instrument. Manufacturers rarely give this information out. Normally they will provide a DLL to communicate with the instrument.
Thus, in your case, VISA is not going to be an appropriate API to use for a USB camera.
Out of curiosity, what prompted this question?
(2,565 Views)
