which pins do I use for 5V output of a CB 50-LP connector block ?
I have the PCI-6025E and the CB-50 LP. I am trying to determine which pins are used to get a 5V output to connect my load cell to. As I understand, there are a set of pins for 5V and a set of pins for 10V. Also is this a continuous output or do I have to be running LabView?
Thank You,
JustinMRice
(3,793 Views)
A way to find information on products is to simply use the Search box at the top of the page. You can look at the I/O Terminals at http://digital.ni.com/manuals.nsf/websearch/91DE6638D38E621A862570CF006F23D1. The later versions of DAQmx have the terminal diagrams in the help file.
There are +5V power pins available. This is fixed. There are also a couple of progammable analog outputs. These outputs can be set between -10 and +10. You need some programming language (not necessarily LabVIEW) for these.
(3,788 Views)
@Dennis
CB-50 LP is not included in the accessory list available for 6025E in DAQmx. All reference pdf listed for CB-50 LP are less than helpful http://sine.ni.com/nips/nisearchservlet?nistype=psrelcon&nid=13591&lang=F&q=FQL:(locale:fr+OR+locale...).
Your link was useful. Thanks!
(3,499 Views)
